Re: Stuck switchover gas/diesel
Posted by Troy in MI on January 15, 2006 at 16:46:34 from (216.65.162.195):
In Reply to: Stuck switchover gas/diesel posted by WV on January 15, 2006 at 16:19:41:
There are quite a few locations in the mechanism that could be the issue. However, I had the same problem on a 400D that I purchased this summer. I found that the problem was that all of the compression valves were frozen in the closed position. I found this only after I removed the cylinder head. It was an easy fix after that though. I just sprayed some PB Blaster on the top of each valve spring and began to lightly tap on the top of the valve with a hammer. After a few minutes, all four were loose and ready to go. I put the head back on and the lever worked like it should. Instead of removing the head, you might check the compression valves by removing the valve cover and checking to see if you can push the caps on the compression valves down. If not, you might be able to loosen them by spraying with solvent and tapping.
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
