Re: Farmall B won't stay running fixed maybe
Posted by P Backus on January 02, 2006 at 21:04:29 from (69.128.32.197):
In Reply to: Re: Farmall B won't stay running fixed maybe posted by Carpenter turned shade tr on January 02, 2006 at 17:19:14:
It sounds like you"ve got a case of the gremlins! The fuel problem and the starter problem are unrelated, but as I always tell myself, anything that moves can break. As with all starter problems, check to make sure that the battery terminals are clean and tight, the ground is clean and tight, and all other terminals are clean and tight. Make sure that the battery is charged. If you have a volt/ohm meter, check for voltage at the starter terminal when you push the start button- if not there, move back down the cables until you find voltage. That should isolate your problem. If the starter has voltage, tap on it a bit. Then take the bolts that hold it on loose- sometimes the gear jams against the flywheel and that should free it up. The starter grounds through it"s base, so that must be clean and tight. Let me know what you find or give me more symptoms- I enjoy the mental exercise! These machines are tough and simple and reliable, once we get the bugs worked out. Paul
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
