Re: Still No Spark!!!!!
Posted by John T on November 29, 2005 at 07:26:58 from (66.244.90.98):
In Reply to: Still No Spark!!!!! posted by Short Bolt on November 28, 2005 at 21:24:45:
Short Bolt, that flashing test lamp on the coils low side and at the points terminal tells me the coils primary has voltage to it ((not sure if enough however?? use a voltmater over on the coils high input terminal to find out or just hot wire to the coils input to eliminate any ignition switch or wiring problems n see what happens),,,,,,,,, and is continuous,,,,,,,,and the points circuit is working and closing a good connection to ground,,,,,,,,and the condensors likely not shorted, and those are all a good thing n necessary. Soooooooooooo, is the coil firing?? I suspect it is !!!!! Remove the coil wire end from the distributor cap (leave coil end intact) and place that bare end to within 1/8 inch from tractor steel, turn her on n crank her over n see if a good blue spark is jumping that gap???? It should each time the points break open, does it??????? Thennnnnnnnn if the coil is firing, replace the distributor cap n try the plugs, are they all firing when removed from the engine with their wires atatched but sides up against ground??? If not, theres a cap or rotor or plug wire or plug problem IFFFFFFFF you have the correct cap and its in time in register with the distributor that is, which I suspect is so. To fire the plugs, the cap n timing have to be correct so that when the points break open the rotor tip is lined up with one of the internal cap tower pick ups. If the plugs or plug wires seem to be firing, the next question is are they firing at the right timing ???????????????? If shes not in time, one may get backfiring or loud pops n bangs out the exhaust or firing back out the carb etc. Just because the coil fires and all plugs fire dont mean the distributor is in time with the rest of the engine BUTTTTTTT she may well pop n bang n backfire if thats the case, does it??? Or it just do NOTHING??? If it is in time, when the number one cylinder comes up to TDC on its Compression Power Stroke the points should be breaking open PLUS the rotors tip lined up with the internal tower pick up thats connected to the plug wire to the number one cylinder and then the cylinders that follow. See if the coil is firing per the test above,,,,,,,,,See if the plugs are all firing per the above,,,,,,,,,then see if they are indeed firing at the RIGHT TIME??????? Let us all know, good luck n God Bless John T
Home
| Forums
Today's Featured Article -
Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
