Re: Help with 5288 split
Posted by JJK on November 27, 2005 at 15:53:24 from (216.189.131.25):
In Reply to: Help with 5288 split posted by WFE on November 26, 2005 at 17:54:28:
You won't see a starter on a 50 series under the floor plate because thats on the left side of the engine but you still need to take the plate out to get the two bolts loose on top of the bell housing. Once the tractor is split, everything loose from the engine, and the engine supported with a cherry picker, remove the front mounting bolts for the engine and all the bolts for the left frame rail you can then remove the engine. Check the flex plate on the flywheel to see if needs replacing, check the cam lift to see how bad the cam may be wore, and have your radiator checked for leaks and blockage as long as your that far. These are some things that need to be checked for sure on IH's. Also if you do the radiator, when you put it back in make sure you seal it back up with the foam so it pulls air from where its supposed to. Best of luck to ya!
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
