Re: Help with 5288 split
Posted by JakeF on November 26, 2005 at 19:21:44 from (64.146.188.222):
In Reply to: Help with 5288 split posted by WFE on November 26, 2005 at 17:54:28:
When you loosen the bolts that go through the frame and the 1 1/2" plate as you call it don't take them out, just make sure they are unthreaded all the way, or the back of the engine will drop as you split it. Also reove the fan drive shaft and all tinwork if you hav'nt. Make sure the front end is blocked so the axle can't oscilate and the weights are removed. To pull the engine you'll remove one frame rail and pull it out of the side. The 1 1/2 plate is bolted to the block and to remove it you first pull the flywheel. Also make sure to remember the 2 bolts that come in from the bellhousing into the rear engine plate when splitting. You get to them from the starter access plate in the floor of the cab. You'll also need the propper rear main seal/wear ring installer to put it back together. I would also pull the manifolds, oil cooler and filter housings off before pulling the engine, but My otc stand uses the oil cooler and filter holes to mount the adapter plate to. Hope this helps. Jake
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
