Re: Is it possible and how much?
Posted by chadd on November 17, 2005 at 05:55:45 from (155.92.31.99):
In Reply to: Re: Is it possible and how much? posted by Nat on November 17, 2005 at 05:16:05:
Yep, but if you look between the liftarms, on the rock shaft, there is a third mounting location. Our 460 utility had a similar set up. It alowed the 2pt to be used like a three pt. All you needed to do was remove the drawbar, insert the arm extensions into the tubes, and then attach a third mounting plate on top of the rockshaft, and you had a three point. It took 5 minutes to convert, and we removed it from our 460 when we sold it and use the same exact kit on our 806. It works like a charm. So he could just install a 2pt and then get a kit to make it a 3pt, although it would be a LOT cheaper to just find a tractor with one or the other.
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
