Re: Fan Belt Adjustment On M
Posted by Haas on October 25, 2005 at 07:09:42 from (12.65.55.249):
In Reply to: Fan Belt Adjustment On M posted by Paul in WI on October 24, 2005 at 18:19:45:
No one mentioned the "rocker" mechanism at the front of the fan. That has nothing to do with the fan belt tension. It is the driver for the water pump. The M water pump is designed with a "floating" shaft and there is no stress on the water pump shaft from the fan belt. The water pump housing extends all the way forward to the fan. On that extension, the fan pulley runs on ball bearings that you grease through one of the fittings on the water pump at the front of the engine. The fitting at the front of the fan is attached to the rotating hub with two studs and then keyed to the front of the water pump shaft with a tapered bolt. That is what drives the water pump. Packing beween the water pump shaft and the housing on which the bearings are mounted keeps the coolant in. I hope this is not too confusing. I suggest you get a manual that shows a cross section of the water pump and you will understand it better. Also, one of the grease fittings at the water pump is for the fan hub ball bearings and the other for the water pump packing. Grease these only once a year and then do not force the grease in. A couple of strokes of the gun is enough. More and you will just force the bearing grease seals to leak and the assembly will sling grease all over the front.
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
