Re: Farmall H stuck in 5th gear
Posted by captaink on August 29, 2005 at 09:13:17 from (66.115.214.56):
In Reply to: Farmall H stuck in 5th gear posted by Jonfarmer on August 29, 2005 at 09:02:01:
It sounds to me like when you shifted out of fourth, the 4th -5th shifter rail coasted into 5th or when you shifted out of 5th, the rail didn’t come out completely and is still in 5th. You can check this out by removing the shifter lever. This is done by knocking out the soft plugs on the side of the shifter tower and then sliding (or possibly lightly driving) the pivot pin for the shifter out of the tower. The shifter can then be removed and you can look into the hole. You should see four thin (less than 1/16th inch wide) guides and the three shifter rails (about 3/8 inch wide) with about ¾ inch notches in them. The notches should all align up across when the transmission is in neutral, but more than likely the one on the left hand side will have the notch ahead of the others. You can take the shifter or a long screwdriver (or other “lever”) and move this rail back in line with the others and your tractor should then be in neutral. The bottom of the shifter is probably worn and not a nice rectangle any more. I would suggest building this up with a welder (or have it built up) while it is out so that it is reasonably snug in those shifter rails or this will happen again.
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
