Re: Farmall Super C Timing
Posted by scotty on August 09, 2005 at 10:24:05 from (199.231.49.128):
In Reply to: Farmall Super C Timing posted by Barry Huff on August 09, 2005 at 09:58:13:
Barry, Start by putting the timing light back in your toolbox! You dont need it. Now that you have found the line on your flywheel, remove your sparkplugs and have a friend hand crank your motor slowly while you have your finger over the #1 plug hole. When you feel pressure coming out you are on your compression stroke.Loosen the bolts on your magneto and rotate the top of the mag towards the motor. Crank the engine slowly until your line on the flywheel lines up with the middle line on the dust cover. It will help to use a white marking pen on that flywheel line. Now, rotate the mag until you hear the impulse coupling snap and tighten in that position. Remove your cap on the mag and your rotor should be in the 2 oclock position. Thats it. Good luck! scotty
Home
| Forums
Today's Featured Article -
Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
