Re: McCormick Deering WD-9 Engine Problem Question
Posted by Haas on June 18, 2005 at 18:31:30 from (12.65.48.211):
In Reply to: McCormick Deering WD-9 Engine Problem Questions posted by billcrews on June 18, 2005 at 06:17:50:
Like Geoff, I am amazed it will start with the starter on diesel. Are you using ether??? Best you not be doing that. Also like Geoff says, the starting lever is connected through a linkage to a mechanism that operates butterfly valves in the manifold to direct air though the carb when in gas postion. Also releases the carb float to allow gas to flow. In diesel position, the float should be locked up stopping gas flow. Also the lever works a switch located in a chamber in the front of the manifold to shut off the ignition in diesel position, but it sounds as though you have disconnected that. All this in addition to working the compression release valves. The lever should stay in gas position by itself. You should not have to hold it. You need to get a service manual which will tell how to adjust the linkage. Also be sure your timing is correct, as the breaker point cam only has two lobes and gears between the lobe and the dist rotor so two lobes can work four cylinders. If you have that 180 degrees out, it will not start and will backfire through the air cleaner and likely blow oil out the intake. Hope this helps and good luck!!! When correctly adjusted, these gas start diesels start real easy. My MD rarely turns over more than two times before it catches.
Home
| Forums
Today's Featured Article -
The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
