Re: TO: JB2 Farmall28 B-414 Questions
Posted by George 2 on April 19, 2005 at 18:23:02 from (216.46.141.114):
In Reply to: TO: JB2 Farmall28 B-414 Questions posted by PaulG on April 19, 2005 at 10:53:13:
B414 gas has 36 PTO HP. Do not use multigrade oils. SAE 30 in the summer and SAE 10 in winter. You should use low ash oil such as Case IH No 1. Reason is that these engines are sensitive to clogging of oil pump screen from ash in the crankcase. Serial number is on right hand side of clutch housing and just in front of your right foot. The engine serial number is on the right side below the hydraulic pump. It starts with BC144 and then the number. Compression should be 120 psi or greater. Oil pressure is more the issue from worn main bearings than are worn piston rings and oil consumption. Mufflers were either vertical or downswept underneath the tractor. Aftermarket mufflers are available. I am in the process of restoring a B414 gas that my parents bought new in 1963 and suggest you get an oil pressure gauge to replace the idiot light as these engines had low oil pressure when the main bearings need replacing. The center bearing is vulnerable as it also has the thrust bearing also.
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
