Re: loose fan shaft
Posted by haas on March 23, 2005 at 18:56:08 from (12.65.31.172):
In Reply to: loose fan shaft posted by tn terry t on March 23, 2005 at 18:18:24:
I've worked on the M water pump, but not an H. However, I think they are basically the same. There should be two grease fittings on there. One greases the bearings and the other the packing. If fan has play in it (that is you can move it up/down and side to side) to speak of, then the only fix will be new bearings and while you are at it new seals. If it's only in the water pump shaft, then new packing should do it. The fan assembly has two ball bearings that are grease lubed with all the associated seals (front and back end). The water pump shaft drives off spring loaded assembly attached to the fan and is full floating so there is no load from the fan belt on the WP shaft. This is an exceptionaly well designed set up and when you take it apart, you will realize why they are still running after 60 years, mostly with no trouble. If the rattling noise is just from the fan, maybe the bolts that hold it on are loose. The M service manual has a very good cross section of the WP set up. I suppose the service manual for the H would show the same. Well worth the price of a manual reprint it you are into restoring the tractor. Also, to get to that thing to work on it, nearly essential to remove the radiator.
Home
| Forums
Today's Featured Article -
The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
