Re: Governor setting on a Super A
Posted by Paul in Mich on March 09, 2005 at 13:05:37 from (64.12.117.13):
In Reply to: Re: Governor setting on a Super A posted by WOD on March 09, 2005 at 08:51:38:
WOD, The first thing I"d do is check the operating linkage to make sure nothing is binding or lost motion, and correct anything that would cause such a condition before doing anything to the governor assembly itself. Once that issue is solved or satisfied, and the problem you state still persists, consider the fact that the governor weights could either stuck into one position, or broken, since the fast idle shouldnt have changed once it had been set. Now then, if you have been into the governor and had it apart, then adjustments would be necessary. High idle speed adjustment is made with the speed change lever in wide open position by turning the adjusting screw which is located on the top of the governor housing.
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
