Hard starting H Tuesday-long post, long morning
Posted by williamf on February 24, 2005 at 14:06:48 from (66.82.9.24):
![third party image](http://www.wimmark.com/distoutside1.JPG)
Tuesday was one of those days that the night before was cold and the morning was foggy. So everything metal in the tractor shed was dripping with condensation. (And you can tell at a glance where the water level in the rears is.) I checked the oil and radiator, hopped up on the seat and rr-r-r-r-r; not even the slightest hint of firing. I wasn't having the brightest day, I immediately decided I had flooded it and started messing with the carb. Cut off the fuel, drain it, try again, take the air cleaner hose loose, generally waste time for thirty minutes or so. Finally I move on to checking for spark. I take the coil wire loose, hold it close to the oil filter cover and push the starter buttom. Not an easy stretch, but good spark. Put it back on and waste some more time trying the starter, the choke, flooding, wah, wah, etc. Then pulled off a plug wire and tried that. No spark. Took the distributor cap off. It looked ok to me, not wet, anyway. A little powdery metal, some blackening on the posts and rotor. I wiped it out,scraped off what I could, put it back and tried again. Nada. Took it back off and sprayed the inside thoroughly with CRC Electric Equipment Cleaner. Let it dry (takes seconds; I don't know what that stuff is; looks sorta like ether, but says non-flammable), put it back together and it fires off like there had never been anything wrong. So anyway, I eventually get to a question. This hasn't ever happened before, even when caught out in the pouring rain. Why now? I don't mind a bit getting a new cap and rotor, in fact I'm ordering them soon as I get done with this, but is there anything extra to help keep it dry inside? Or was it more likely a cleaning or wear problem? Somebody suggested there might be a crack too small to see letting moisture in, but as you can see in one of the photos there's a (I guess) vent hole in the side of the cap already. Also, and BTW, in the inside photo you can kinda see that the posts ( is there another name) show the most wear and blackening at the edge where the rotor button leaves contact. Is that fairly normal or does it mean something? The tractor does run amazingly smoothly, I hesitate to mess with, for instance, the timing. Thanks for putting up with my ramble. Wm Here's what the outside looks like:
Home
| Forums
Today's Featured Article -
Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
