Also i shoud add that when it was working normally every time i would turn the ignition switch on the amp meter would always show a 10 amp discharge. It might not actually be 10 amps as it is a 12v conversion. Even if i take the fuse out and turn the ignition switch on it still shows that 10 amp draw. I will Try a jumper wire and see if she will throw a good blue spark. It does turn over real good so the battery has plenty of juice. All the other tractors i worked on had the 6 volt gene or a mag. thanks john
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
