My first impression is a bad connection in the circuit supplying the ignition switch and possibly the connection at the load side of the amp mmeter. The amp meter showing discharge might be from a short that caused the problem, or it could mean there is a bad wire going to the coil. I would remove the wire from the coil (ign sw side)and see if it has the same draw. if not it could be a shorted coil. This would burn up the points,, and cause other issues with wiring. If the 10 amp load is not there, I would not hook up a hot wire until I found the short to ground or bad coil. Let us know what happens. JimN
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
