Farmall Tractors Discussion Board
Re: Throttle speed for using tractors.
Posted by HR on November 18, 1999 at 06:00:46 from (209.156.136.50):
In Reply to: Throttle speed for using tractors. posted by Rod Hergott on November 17, 1999 at 17:27:07:
Rod: Refering to the older tractors which did not have a zillion gears, the best economy depends a bit on what the engineer designed into the engine.. how was the cam ground? best economy often is at peak torque which is maybe 2/3 rpm in say an h or m..So if you had a light load and would have geared up and slowed RPM you maybe would have saved gas..Heavy load..no. Lugging an gegine is not good either as very slow RPM lugging increases SIDE loades on the piston etc.. Don't forget that PTO RPM either..That should be taken into consideration right away.. Generally near max RPM was a fairly good choice for tillage.. hope this makes early morning sence...harvey
Post a Followup
: Re: Re: Throttle speed for using tractors.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
