Farmall Tractors Discussion Board
Re: Diesel problem
Posted by JK MN on November 16, 1999 at 08:22:01 from (207.242.199.131):
In Reply to: Diesel problem posted by John R on November 15, 1999 at 21:05:33:
John R
Since that engine starts on gas (low compression), and then is switched over to diesel, (high compression), be sure the compression release system is working properly. ie the compression release valves adjusted correctly, and also the engine valves adjusted correctly. Since only the head was worked on, I would first start in this area.
Post a Followup
: Re: Re: Diesel problem
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
