Re: H block studs
Posted by Wayne Swenson on September 04, 2004 at 19:18:07 from (66.191.70.31):
In Reply to: H block studs posted by Dale L on September 04, 2004 at 15:42:54:
My son & I just finished an "H" engine rebuild. We took all the bolts out to more easily remove the sleeves. The long bolts are located as follows: in the center of the head are 3 bolt holes with a circular pattern around the them. They are nearly under the rocker arms. These 3 are where the 3 thick washers go so the bolts need to be a bit longer. On the left side of the head the throttle pivot bracket is located; it needs 2 longer bolts also. CAUTION #1: Be sure to put a sealant on the threads when installing if the bolt hole protrudes into the cooling passage. (poke a wire into the hole to see if it it bottoms out or goes on into the cooling passage. CAUTION #2: measure the thickness of the head plus gasket thickness and only thread the bolts in far enough so the nuts can have full thread engagement. We had to back some bolts outa little when the nut only had 3/4 of the thread used. Experience, you know!!
Home
| Forums
Today's Featured Article -
Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
