Re: 300 utility (again)
Posted by Unreserved dick on September 04, 2004 at 08:44:55 from (4.228.129.66):
In Reply to: 300 utility (again) posted by RRI on September 04, 2004 at 04:50:29:
On your possible fuel problem, this is pretty common with these tractors, often the root cause is a rusted gas tank. Things to check: gas cap vent plugged (resulting in pulling a vacuum on the tank), partially plugged filter at inlet to carb (at the end of the fuel line where it connects to the carb - this is the real choke point of the fuel system and many people don't realize it's there), crud in the bottom of the tank (empty the tank, pull the strainer off the bottom, and see what you've got). Some people end up lining the tank, but thus far I've been able to avoid it. Your carb probably has a drain plug which you can use to test the fuel supply - if you get a good sustained, pencil-sized flow you should be OK. On the coil, some people use a "ballast resistor" with a 6-volt coil in a 12-volt conversion, but my preference is a new 12-volt coil (more readily available at this time, anyway) which avoids the Mickey Mouse wiring that the ballast resistor requires. Another possible cause of your stalling problem is a defective coil, so this would be part of a shotgun approach to solving that problem as well. Hope this helps. Good luck.
Home
| Forums
Today's Featured Article -
The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
