Farmall Tractors Discussion Board
Re: Re: Re: IH 240 engine miss
Posted by Farmer Bob on November 01, 1999 at 20:32:52 from (207.227.187.53):
In Reply to: Re: Re: IH 240 engine miss posted by B. Rust on November 01, 1999 at 20:02:32:
B. Rust, Check the oil after a warmup period, if it's milky looking good chance you have a blown head gasket. To check a cold engine, open the oil drain plug "very slowly" to see what comes out first. water or oil. As oil is lighter than water you should get water "first" if the head gasket is gone. My opinion is you have the misting problem over the wiring/dist. causing the rough running as it doesn't take much dampness to arc across escially with graphite filiment wiring. Good luck. FB
Post a Followup
: Re: Re: Re: Re: IH 240 engine miss
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
