Re: Starting Problems- Farmall C123 Eng.
Posted by El Toro on June 08, 2004 at 12:13:30 from (205.188.117.22):
In Reply to: Starting Problems- Farmall C123 Eng. posted by Jerry in WA on June 03, 2004 at 08:04:08:
Hi jerry, Did you ever get your tractor started? If you didn't remove No1 sparkplug and hold your thumb over the plug holew while someome slowly cranks over the engine. When you feel compression against your thumb stop turning engine and look to see where your timing mark is your damper pulley. When you locate the timing mark on the pulley you should be the timing pointer. Rotate engine slowly until both the pointer and the timing mark on the pulley are aligned. Remove your distributor cap and see if the rotor points to No1 plug. If it does your distributor is in time. Check plug wires to the other cylinders. If rotor turns CW the next wire is to No3, then 4 and 2. If the rotor isn't on No1, pull distributor and rotate rotor to the No1 position. Do not move the engine while your're making this change. Good Luck, Hal
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
