Re: IH 966 Hyd. Question?
Posted by Big Jim on May 20, 2004 at 09:53:24 from (199.141.125.33):
In Reply to: IH 966 Hyd. Question? posted by J.D. on May 20, 2004 at 05:12:48:
JD Aces is right about the plate. Unfortunately, I am not aware of an aftermarket source for the adapter plate. You will have to go to your Case-IH dealer and it will get quite spendy. The plate is well over $100. It looks like it cost them about $10 to make. You take the plate off of your existing control valves and bolt the new plate in. Then screw a hose into the port on the new plate and run it to your add-on control valve "in" port. Then you will need to run another hose from the "out" port back to your reservoir. You can run the return oil just about anywhere you can find an opening to put it back into the tranny.
Home
| Forums
Today's Featured Article -
Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
