Re: H -broke in half-
Posted by Loren Arends on April 11, 2004 at 21:29:08 from (207.190.105.242):
In Reply to: H -broke in half- posted by Bob on April 11, 2004 at 17:31:12:
Buy the repair manual and if you can find an old set of steel wheels with about a 1 to 1 1/2 in axel like the rear wheels of an old hay stacker. cut a shaft about 6 inches wider, on each side then the center of the tractor weld a piece of 3 inch channel iron on the shaft between the wheels this is where you can set a bottle jack now get 2 pieces of 2 inch angle Iron about 3 feet long. The wheels set under the front portion of the transmission. The angle iron bolt rear ward on the upper axel housing bolts and then to tabs that you weld to the rear edge of the channel iron. If you have a narrow front tractor you also need to make a tripod angle brace, I use 3 inch angle iron up from the floor to the mid to upper third part of the engine for balance, out about 3 foot on each side with a piece running across to the braces at the bottom. I put 1/4 inch x3x3 plates with a hole in it near the outer edge and put thread rod in it with a nut welded to the bottom as a set of leveling screws then jack the tractor up to level and side the rear away
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
