Re: Re: Re: Rough running M farmall Day 2
Posted by Ray in Pa. on March 18, 2004 at 20:58:01 from (205.138.20.109):
In Reply to: Re: Re: Rough running M farmall Day 2 posted by dave w on March 18, 2004 at 18:49:12:
I would remove distributor cap from distributor, and then slowly rotate engine by hand to have the cam in the distributor open the points fully, then check point gap setting. Now slowly rotate engine by hand so that the next cam lob opens the points, then check this point gap setting to see if its close to the first lobs point gap setting. Now repeat this with the last two lobs to see if all your lobs have close to the same point gap setting. This way you can rule out whether the cam and its lobs are faulty or not. Just be sure that when you rotate the engine by hand, that you rotate it in the same direction that it turns when running. Another thing to check for would be excessive carbon in spark plug hole. Carbon build up can get to the point where it will narrow the hole in the lower threaded section of the spark plug hole and could possibly cause miss firing. Excessive carbon in the combustion chamber can also cause a localized hot spot and miss firing. Generally though, this is usually rare and can sometimes be corrected with a good carbon cleaner additive added to the gasoline and run alittle. Thanks, Ray in Pa.
Home
| Forums
Today's Featured Article -
Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
