Re: Re: ID 9
Posted by Bob M on February 27, 2004 at 08:17:58 from (165.170.128.66):
In Reply to: Re: ID 9 posted by rustyfarmall on February 27, 2004 at 05:02:41:
Rusty – A leaking manifold can only cause a miss when the engine is in gas mode. Once it’s switched over to diesel the motor will run fine with a leaking manifold. (In fact it would continue to run even if you were remove the manifold!) Gordon – Regarding the miss, when the engine is fully warmed up on diesel is the exhaust clear or does it puff white? If it’s clear it means the missing cylinder is not getting fuel. Try bleeding out the #1 injector. If that doesn’t do it try swapping the #1 injector with one of the other three (be sure to bleed them both out after swapping). If #1 is still not firing problem’s gotta be with injection pump. However if the problem follows the old #1 injector to it’s new cylinder location, you’ve got a bad injector. If white is showing in the exhaust, it means the misfiring cylinder is getting fuel but doesn’t have the compression necessary to fire it. Carefully check/reset the clearance on all (3) valves on #1. If it still doesn’t fire you’ve either a valve problem or bad rings. Good luck!
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
