Farmall Tractors Discussion Board
Hydraulic Oil and ?
Posted by MrGadget on October 16, 1999 at 12:00:30 from (207.91.28.133):
I was going to change the oil in the trans/dif on the 560 today. Drained about a qt of water outa the lower rear, and a cup or so outa the front before I got to pure oil. Since it is apparently seperating, must not be Hy-Tran, cuz that will absorb water, right?
I can still stick my finger in the sight plug hole and find oil very close to full. So I'm not too anxious to change it if I don't have to. Was going to add some oil with what I had before spending $80 on Hy-Tran. Assuming that's what I actually need(?).
I have a 5 gal bucket of Univis N46 High VI hyd oil. Meets Denison HF-0, HF-2; Milcron P-70; Vickers I-286-S, M-2950-S. It's almost clear. Is this anything close to what I should put in there to top it off? If not, what CAN I use this stuff for? Price was right, I got at a farm sale, unbroken seal for $1.
Also the guy at the parts counter said that my tran/diff and hydraulics are all one big reservoir. I'm not so sure about that, becasue there appears to be a second smaller case in between the engine block and the transaxle case. This smaller case includes the clutch bell housing and has a rectangular plate under it, with a drain plug that requires a 1/4" square allen type wrench to remove it (which I don't have). WHat is this casting, and is it connected to and sharing the same oil as the trans/diff? If seperate, what do I need to do to service it?
The manual is on order, but I'm too antsy to wait. I want to use my tractor!
Post a Followup
: Re: Hydraulic Oil and ?
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
