Farmall Tractors Discussion Board
Can an IH 6v generator be converted to output 12v?
Posted by JR on October 15, 1999 at 09:25:08 from (208.216.106.99):
I have a 1947 IH I-4 tractor with a working 6v generator. However, the engine will seldom start when on a (new) 6v battery. A 12v battery works great. I would like to keep the positve ground system and convert the generator to output a high enough voltage to charge a 12v battery. Is is possible to do so? The generator is a Delco-Remy with the "voltage regulator" mounted on top of it. The "voltage regulator" only has a single relay. Is that only used to connect the generator to the battery when running and disconnect when not running? The generator and wiring match the parts shown in a parts manual for the system without lights. Help!
Post a Followup
: Re: Can an IH 6v generator be converted to output 12v?
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
