Farmall Tractors Discussion Board
too many bearings!
Posted by Jon with an H on October 15, 1999 at 07:29:37 from (207.239.152.110):
I pulled the front hubs off the H to check the bearings. I had a clicking noise when the wheel was spinning. What I found was a mess. The original owner had a bering failure and had replaced it without removing the old peices wich were up inside the casting. My front hubs are cast and have a cavity inside. I pulled out loose bearings and chunks of race that had been smoothed off from bouncing around inside there for years! The inner bearing was loose because the axle has been worn down. It has been suggested that I have it machined and bushinged, but I would like to replace it. I have been told, and the parts manual seems to support it, that the front axle and lower bolster are one peice. But! There is a large rivet passing through the lower bolster and axle as if it holds the axle inplace and at the correct angle. So what do you all think, has anyone ever replaced an axle? Was it pressed in at the factory never to be removed again? I am prepared to replace the lower bolster, but also curious why it was made that way.
sorry, looks like I went on for a while.
Jon
Post a Followup
: Re: too many bearings!
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
