Farmall Tractors Discussion Board
Re: Farmall B won't shift into gear.
Posted by Ludwig on October 14, 1999 at 14:34:57 from (208.201.105.253):
In Reply to: Farmall B won't shift into gear. posted by Shawn Frasier on October 14, 1999 at 09:18:57:
Is the clutch disengaging? Try starting it in gear with the clutch depressed. Be very carefull doing this as the tractor may lurch unexpectedly.
Another way to test is to tow it behind a truck in gear with the clutch down. If your not sure if the engine is turning let the clutch out a bit, if the puller labors more it's not the clutch.
Post a Followup
: Re: Re: Farmall B won't shift into gear.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
