Re: Re: Re: Starter for M
Posted by rebuilder on January 27, 2004 at 09:03:54 from (66.228.102.103):
In Reply to: Re: Re: Starter for M posted by KX on January 27, 2004 at 07:20:40:
KX; My first question is how did the stud(hot bolt) come loose? Did you over tighten it or too much cranking melting the solder away? I see alot of both. When, if ever, has this particular starter been rebuilt? If the stud came loose from excessive heat from too much cranking or other electrical problems I am concerned about the condition of the coils. Is the insulation(paper wrap sometimes dipped in varnish) charred or bubbled? How do your leads to the brushes look? Are they charred or bubbled? To more directly answer your question, you should be able to get any Delco starter parts you need from you nearest NAPA store, although I doubt they will have the parts on hand a will have to order them in. If you have a parts book for you tractor, the actual delco #'s are listed as MFR #'s I.E. Both parts you are looking for are called Terminal Stud Insulation Washers--- part #1861076 and 1904669. These are old delco part #'s and may need to be superceded. You will need two of the large washer and three of the small washers which fit inside the casing( the book only calls for two). I don't recall at the moment which Part # goes to which washer. For your reference I get these from my supplier for pennies each although you will have to allow for shipping & handling charges which will cost more than the parts. Also, as you put your starter back together, perhaps you should have NAPA dress you armature up(the commutator end where the brushes ride gets pitted and corroded). and definately put new brushes on. Lastly any solder you have should be good enough for what you are doing. Just make sure you have the stud cleaned well and the coil end also. Make sure you get the coil end seated well in thes tud or it will rubb against the armature if you let it stick out too far. I use a small visegrip to hold the coil ends in and heat the stud FROM THE OUTSIDE so as not to damage the coil insulation. You will have to have the inside washers on befoer you solder, but I add the outsides later to save them from heat damage. Alright, that should be enough to get you started since I could keep going!
Home
| Forums
Today's Featured Article -
The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
