Re: B crankshaft pulley removal
Posted by rebuilder on January 24, 2004 at 17:50:39 from (216.241.134.87):
In Reply to: B crankshaft pulley removal posted by Kenneth on January 24, 2004 at 16:58:36:
Kenneth; We have encountered that problem many times on the C-113/123's. I remember some that, even with thpuller installed, we still had to heat red hot with a rosebud to remove. You're best bet would be to see if you can borrow or rent a T-puller and a bearing seperator form a shop in your area. The bearing seperator goes behind the flanges on the pulley and the T-puller bolts to the seperator. The T-puller shaft "should" fit through the hole in your pulley. There is another way to take these pulleys off without that setup. If you remove the crankshaft and unbolt the front cover from the engine, you can then put the offending pulley in a press to do a more accurate job. Many other like you have had this problem & failed and so you should be able to find a new(aftermarket) pulley somewhere close. I know we sell quite a few at the yard I work at. Good luck.
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
