Re: Help: Rebuilt head / new valves, 1949' C
Posted by Randy in NE on November 26, 2003 at 04:23:32 from (216.58.237.20):
In Reply to: Help: Rebuilt head / new valves, 1949' C posted by Josh on November 25, 2003 at 19:00:57:
Make sure you have the correct head gasket. My '50 C had 3 1/8" instead of the 3" pistons. Had trouble finding the correct gastket to match up with the water ports. Most of the 3 1/8" head gaskets assume you have a water pump so the water port holes are smaller. Ended up drilling them out to get better cooling flow. I used a high temp silicon and put a light coat on both sides of the gasket. If you check the archives others spray on a couple of coats of sealer. Be sure to start your torque sequence from the center and work out. I started torquing at 40 ft-lbs and worked my way up to 80 ft-lbs going in 10 lb increments. After you have run it for a while you will want to remove the valve cover and rocker arms and re-torque the head. This means resetting the valves. No big deal. The manifold is torqued to 20 flt-lbs. Valves are set to 0.014"
Home
| Forums
Today's Featured Article -
Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
