Farmall Tractors Discussion Board
Re: Geting a tractor to run after it has set fo a while
Posted by Dan 130 on October 03, 1999 at 12:46:40 from (209.144.69.172):
In Reply to: Geting a tractor to run after it has set fo a while posted by Steve on October 02, 1999 at 20:18:39:
Steve, you can almost always count on the points being corroded if it has set for a long time. Go to an auto parts store and purchase a point file and clean them up. It will make sure you are getting a good point contact, which should give you a good hot spark assuming everything else is OK.
Post a Followup
: Re: Re: Geting a tractor to run after it has set fo a while
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
