Re: Trusty ole M ainta' charging!
Posted by Doug in OR on June 29, 2003 at 15:20:22 from (12.225.51.197):
In Reply to: Trusty ole M ainta' charging! posted by 49 Cubber! on June 29, 2003 at 07:48:54:
I use digital voltmeters at work. Nothing but them. Mine is calibrated to the third decimal place, but I never need that kind of accuracy. Digital or analog, either works well for me. Anyway, do this: remove the field wire from your generator. Put the negative lead of your meter (I am assuming you are using positive ground) on the "ARM" terminal of the generator, and tie the other lead to a solid frame ground. Now, with the engine running, short the "Field" terminal on the generator to ground. The meter reading should go from 6 volts to something greater than 7 volts.. possibly as high as 14 volts. If this part works, your generator is fine. I would suspect the regulator is the culprit. The above assumes you are wired correctly and have no wiring problems. Wire problems at the terminals can be a problem - and hard to find.
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
