Re: 1086 air conditioner
Posted by Shawn on June 04, 2003 at 15:07:38 from (205.188.209.140):
In Reply to: 1086 air conditioner posted by Steve Oliver on June 04, 2003 at 03:19:23:
First of all the system would not be overpressured wihtout compressor running. R134 gas, uncompressed will have a pressure that relates closely to ambient temperature, Example 80deg F system pressure will in the 80lb + range. Your system will not overpressure until the 300lb range, & if correctly retrofitted would have pop off valve that expels pressures above 400 lbs"roughly". I think your sytem has a bad pressure sensor on the high side, or a short in wiring of same. i could tell you how to bypas these sensors, but I wont due to possible healthrisk to you & your compressor. To correctly work on the system it must be connected to a gauge set, then you could determine if system pressures are ok. Without knowing the actual pressure in system & hot wiring you could either over pressure & vent refrigerant or burn up a compressor that doesnt have enough refrigerant. In other words let someone take a look at it with the equipment necessary, just guessing on the repair will only cost alot more money if you make a mistake. My 2 cents
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
