Re: 300U PTO adjustment problem
Posted by dick on April 20, 2003 at 17:05:18 from (209.245.14.230):
In Reply to: 300U PTO adjustment problem posted by Dennis on April 20, 2003 at 15:34:29:
Sounds as though your drive band is too loose, if "bogged down" means the bush hog stops cutting under heavy load - and this is because the PTO is slipping and not because the engine is overloaded. I'm not sure what manual you're using, but the way the IPTO adjustment is supposed to work is: With the engine OFF - you should not be able to turn the PTO shaft in either the engaged or the unengaged positions, but MUST be able to turn it (using a rod through the hole in the shaft) with the control handle somewhere in between the two extreme positions (otherwise you're going to have both bands grabbing at the same time, and one or other is going to get worn out very, very quickly). I like to cheat a bit toward having the point where neither band is grabbing be when the control handle is as close to the disengaged position as I can - this means the drive band can be really tight when the PTO is engaged - but you can make up your own mind on that. This is one of those jobs where having a helper to hold the control handle steady while you're fooling around trying to turn the PTO shaft with the handle somewhere between engaged and disengaged is really a big plus. Hope this helps. Repost if you have more questions.
Home
| Forums
Today's Featured Article -
History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's.
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
