Re: Oil seal for Farmall A fanshaft?
Posted by Haas on April 17, 2003 at 18:31:18 from (166.72.245.112):
In Reply to: Oil seal for Farmall A fanshaft? posted by Andrew from Aust. on April 17, 2003 at 05:06:43:
The fan shaft does not have a seal. Possibly the hub is overfilled with oil. There is a little standpipe inside the hub that sets the oil level. Remove the screw in the side of the hub and turn the fill hole to the side. fill up to the hole and then turn the hole to the bottom and let the excess oil drain out. There is a slinger inside to circulate the oil to the sleeve type bearing and centrifugal force keeps the oil from coming out at the shaft. You can have the sleeve bearing replace with a ball bearing, or you can buy a new aftermarket fan assembly that has a ball bearing in it. These replacements usually are "permanently" lubed with no grease fitting. Many of the originals are still going after 50 or 60 years, even with quite a bit of neglect. That won't happen with the ball bearing replacements. If you stick with the original, you will have to tolerate a small amount of oil residue where the shaft comes through the hub.
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
