Farmall Tractors Discussion Board
Cub Electrics
Posted by Chris on September 09, 1999 at 20:59:18 from (216.176.147.40):
I have a Cub with a cutout relay. The battery wire goes into the relay at the BAT terminal and the ignition switch wire runs out from the same terminal to the switch. My question is: Is this setup correct, or should the switch wire run out from the terminal on the other side of the relay coil? Plus, what kind of charge and discharge should I be seeing at idle, loaded, lights on dim, high?
Thanks, Chris
Post a Followup
: Re: Cub Electrics
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
