Posted by karl f on March 29, 2009 at 11:29:55 from (172.130.27.44):
the idle mixture screw on our 400 gas does not affect the idle at all. it runs fine, you can drop it down to about 300 rpm if you want. However, it idles pretty smoky, smells bad too. If you try to start it at lowest throttle even when speed set correctly to about 450, it will overchoke and flood. Also, if you partially remove idle mixture screw, the tractor all of a sudden will idle fast. But, if you completely remove screw it will die. This was a running tractor (always hard starting, rich idle, throttling up even one notch when cold would kill it). I partially disassembled the carb to check float adjustment and other things, and then synchonize governor/carb. I suppose it is a passage i didn't make time to ream out, but which one? I think it is the correct carb for the tractor, the main discharge jet is removed with a nut inside the bowl vs. a screw head on the outside.
thanks for your input. karl f ps i found one float set higher than the other.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
