Re: IH434(424) Jerky Hydraulics?
Posted by Haas on March 08, 2003 at 17:35:14 from (166.72.245.24):
In Reply to: IH434(424) Jerky Hydraulics? posted by BlueLite on March 08, 2003 at 15:37:05:
I hope you have an owers manual, because this will make more sense if you do. Under the seat, or somewhere around there is a shut off valve for the hydraulics. That valve is used if you want to connect a remote. The valve shuts off the hydraulics to the 3 point cylinder (The cylinder is inside the unit). Raise the 3 point with a load on it. Then shut off the valve (Don't try to operate the 3 point with the valve closed). If the load does not stay up, then likely you have a bad seal in the internal cylinder that works the 3 point. If it does stay up, then you have bad control valve that is letting the fluid leak off from the cylinder. I'm betting it is a bad piston in your internal cylinder. I had this problem on the 424 I once owned. It was a bad seal (and piston) on the internal cylinder. The original seal on these pistons was leather. Better to replace it with a new piston that has an O ring seal. The IH piston is very expensive. However, you can use a piston from a Mahindra tractor parts dealer. It will cost less than 1/2 the IH part. That is what the mechanic that fixed mine did. Also, if your piston is still good, you can have a machine shop machine a groove in it for an O ring.
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
