Farmall Tractors Discussion Board |
Re: Re: F-12 crankshaft removal - How do I get the #@!% thing out??
Posted by Paul Fox on September 07, 1999 at 03:17:45 from (204.176.212.3):
In Reply to: Re: F-12 crankshaft removal - How do I get the #@!% thing out?? posted by Ed on September 06, 1999 at 18:07:51:
Pulling the flywheel isn't too hard either. I forgot to mention in my email that there are two "extra" boltholes in the flywheel. After removing all the flywheel-to-crankshaft bolts, screw two of them in these "extra" holes and they will press the flywheel off the crank. If yours is anything like the F12/F14's I've worked on, there won't be a problem as the rear main seal leaks enough to keep that area "lubed" so it should come right off.
Post a Followup
