Posted by Bigdog on March 29, 2009 at 07:26:07 from (71.64.18.18):
In Reply to: Timing a Cub engine posted by Klein Rot on March 29, 2009 at 01:37:07:
With a mag you should have only one mark on the pulley which is TDC. If you have two marks the second mark is TDC. That is the one you use to set the static timing. Once you get above about 400-500 rpm the mag will advance but it is a fixed advance so if you set the static time the advanced time will be correct. The timing procedure for the mag is in the operator's manual.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
