Farmall Tractors Discussion Board
Re: Super A Alternator Conversion!
Posted by Greg on August 25, 1999 at 04:56:44 from (216.128.143.174):
In Reply to: Super A Alternator Conversion! posted by Bill {Antique Acres} on August 24, 1999 at 17:15:17:
Bill, I used the factory gen mount, with a delco internal reg off 78 chev pu. Take a stick of 3/8 allthread 3inches longer than the gen mount, line the pulleys up and measure the distance left, make a spacer to take up the space in the gen mount. Take off the adjusting bracket and turn it over mounting it back in the same hole, that will align the adjuster with the alt. The adj will be short, I made an extension out of 1/4 x 1 flat bar about 3 in long to make up the difference. Take an old fanbelt , cut it to fit around the pulleys to measure for the lenght of the new blt, get this close cause there is not much clearence for the hood. Hope this helps
Post a Followup
: Re: Re: Super A Alternator Conversion!
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
