Re: Oil Bath Air Filter
Posted by Michael soldan on October 14, 2002 at 09:59:21 from (216.46.130.16):
In Reply to: Oil Bath Air Filter posted by Dave IL on October 14, 2002 at 09:46:58:
Dave, I have two 1944 H's and I use the same weight motor oil in the oil bath as is in the crankcase. I could only imagine the engine sucking oil from the oil bath if it was totally overfilled other wise, I am sceptical that it could happen. I am interested in your comment about the tune up. If the carb is not set correctly or your engine valve timing is off you could get smoking and wettness on the plugs. I would suggest a compression test to answer your concerns. If you don't have a compression tester you can borrow or rent one and it doesn't take long to check. If your cylinders are all within 10 lbs of each other and they are between 90 and 120 your smoking is not likely related to ring, sleeve, piston but carb, timing etc. I have one H that is 85lbs across the board and it really doesn't smoke much once it is warmed up. If it has been idling and you open it up it gives oil smoke for a moment , then clears up. I suspect the "tune up" as you indicated. Good luck from Mike in Exeter Ontario
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
