Re: 3 BOTTOM PLOW TROUBLES
Posted by Hugh MacKay on September 11, 2002 at 16:30:20 from (64.228.14.127):
In Reply to: 3 BOTTOM PLOW TROUBLES posted by DCPULLER on September 11, 2002 at 13:08:14:
Just a suggestion, I guess I would want opinion of a good welder. You can buy Farmall front wheels, the type with 3 lugs welded on for use on mid 50s tractors. You can buy those without lugs in 15 and 16 inch. Just maybe a good welder could weld it to your hub and spokes.
Another wheel I have done some work with is the 16 inch dounut rim that came with full size rear wheel drive Chevys and Oldsmobiles
If you are not one, ask a good welder.
Post A Followup
: Re: Re: 3 BOTTOM PLOW TROUBLES
Today's Featured Article - Restoring a John Deere 2010 Diesel Tractor - by Jim Nielsen. Following seven years working in California's Silicon Valley, my wife, baby son and I moved back to Australia to retire. We bought a small 'farm' of about 50 acres near Bendigo, in the state of Victoria. I soon found that it would be very useful to have a tractor around the place for things such as grading our long drive and brush-hogging the fields. I was also embarking on planting 1000 eucalyptus trees, and hence I would need a ripper, small disk plow, sprayer etc. to get these things accompli ... [Read Article]
Latest Ad: 1945 Farmall wide body gas with pto and front plow. Runs good but needs new points. [More Ads]
