Re: super c and little genius
Posted by Brian Schmidt on June 11, 2002 at 20:19:14 from (207.179.198.216):
In Reply to: super c and little genius posted by dan on June 11, 2002 at 18:27:15:
Dan,
Should be no problem if the soil is not real wet, super hard, or super heavy. I have a 49 C and pull a #8 Little Genius 2-14. I also have 3 sets of rear wheel weights and 1 set of front wheel weights mounted when I plow. If the shares are good and sharp and the moldboards are not rusty you will have an easy time. I do sometimes have to drop down into 1st if it is wet or hard. But when it is dry and I am not plowing more that 4-5", I can run up in 3rd.
Hope this helps. Plowing is quite fun. Let us know how it works out for you.
Post A Followup
: Re: Re: super c and little genius
Today's Featured Article - Restoring a John Deere 2010 Diesel Tractor - by Jim Nielsen. Following seven years working in California's Silicon Valley, my wife, baby son and I moved back to Australia to retire. We bought a small 'farm' of about 50 acres near Bendigo, in the state of Victoria. I soon found that it would be very useful to have a tractor around the place for things such as grading our long drive and brush-hogging the fields. I was also embarking on planting 1000 eucalyptus trees, and hence I would need a ripper, small disk plow, sprayer etc. to get these things accompli ... [Read Article]
Latest Ad: 1945 Farmall wide body gas with pto and front plow. Runs good but needs new points. [More Ads]
