Re: Farmall H Issues
Posted by Hugh MacKay on May 18, 2002 at 01:57:19 from (209.226.247.161):
In Reply to: Farmall H Issues posted by Phil on May 17, 2002 at 05:18:11:
If you truly believe there is stuck rings, and I have no reason to disbelieve you based on your discription, I do have a suggestion. Use a spray can of good penetrating oil (I like one called Fluid Film, made from sheep oil or lanolin) Remove spark plugs ample amounts in each cylinder, the idea is to get enough product in there quickly enough so it will flow right around piston. Let it sit for 2-3 days with plugs out. Every 6-12 hours turn engine with hand crank. This will help work fluid down around rings. You will have some problems getting it started after this. If your starter is fast, turn it on starter for 30 sec to blow excess fluid out. You will still probably have to tow it for a start. Run it for 20 min and change oil and filter. On filling with oil you could add STP motor job in a can, thats optional. I never believed in that stuff but did try it on an engine and it worked. I have done this with several engines but only as a last resort. Results have been from good to lo-fair. I wouldn't say poor. I believe sucess on this is based on what you start with. It is a hit and miss, as engine is probably going to have to come apart anyway. One of the tractors I did this to has been going for ten years since and he works the tractor quite hard, when working. Part timer likely 800 to 1000 hours in the ten years.
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
