Re: Belly Pump Questions
Posted by Farmer Bob on May 07, 2002 at 21:07:56 from (66.152.73.134):
In Reply to: Belly Pump Questions posted by Phil R on May 07, 2002 at 20:30:48:
I believe it's called the Lift-all drive shaft or Coupling and Sleeve assembly. Pull the keys and slide sleeves to the middle of the shaft. Then slide the shaft out of the slots at both ends. Take a flat bar (Or like me) use a 24" wrecking bar to break that aft coupling loose. It turns out (CCW)like normal threads. It will be rather tight but should break loose without damage to the coupler. Then remove the seal from the retainer with a good seal puller. If it's original, it will be the old leather/spring type seal, Replace it with a new seal. Check the outer surface of the coupler for a wear ring caused by the old seal and try to place the new seal where the seal will ride on a different area of the coupler. You may also need to use a speedy sleeve on the coupler to get a good seal but I doubt it is that bad. Good luck.//FB
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
