Re: 350 alternator
Posted by Bob M on April 26, 2002 at 19:32:05 from (66.66.72.246):
In Reply to: 350 alternator posted by Kirk on April 26, 2002 at 16:25:10:
The 10 ga wire goes to the BAT stud on the back of the alternator. To figure out the two auxiliary wires you'll need a voltmeter or a test light. With the ignition switch OFF, take a voltage reading from each wire to a good ground. The wire that shows no voltage goes to the #1 terminal. The other (which should show 12 volts) get hooked to the #2 terminal. To test the alternator on the tractor, all the wiring must be correctly hooked up. You can then bypass the internal regulator and drive the alternator to full output as follows: Look on the back side of the alternator for a small (3/8" or so dia) hole in the back. About 1/4" inside this hole there should be a small metal tab (the test tab). With the motor running at about 1/2 throttle, carefully stick a small screwdriver into the hole until it touches the metal tab. Then with the tip of the screwdriver still touching the tab, angle the screwdriver so the edge of the blade touches the side of the hole. If the alternator is good you should see a large (20 - 30 amps or more) charge on the ammeter with the test tab grounded. Of if you connect a voltmeter across the battery terminals it should show close to 15 volts if the alternator is good.
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
